Bird Brain's latest activity
Bird Brain
replied to the thread
Any way to convert this 3/4 crankshaft?
Outside of a fancy taper lock adapter from keyless to keyed which i could not find, how about something like this angle grinder nut? Its...
May 13, 2024
Bird Brain
liked
mchadsey1's post
in the thread
One drawback as it appears there's no shoulder on the shaft that protrudes past the crank seal keeping a clutch or driver from rubbing...
May 13, 2024
Bird Brain
pull start
Did you replace just the rope or the complete assembly? If just the rope you might have wound it too many turns before inserting your...
Apr 8, 2024
Bird Brain
liked
Kasper's post
in the thread
Coleman ct200 u ex steering bearing replacement?
Ya there is a very small grove, so small I don't know about using a punch, I was hoping the puller would sit in the little pocket where...
Apr 8, 2024
Bird Brain
Engine Specialties
Try researching the original Fantic Motor Company. There do appear to be similar design elements to later Garelli moped frames in your...
Apr 8, 2024
Bird Brain
I understand that. Tight and restrictive space. Well im sure you will get it. This is the correct puller for that job but i didn't...
Apr 8, 2024
Bird Brain
This works also and is a simple garage piece. A coupling nut, 2 jamb nuts, and 2 bolts. One end ground to a point and one end ground to...
Apr 7, 2024
Bird Brain
Whats your honest shop skill level? Thats not meant as insult, but rather gives me a better idea what to suggest. I deal with this kind...
Apr 7, 2024
Bird Brain
HM80 only runs with choke on
Remove your main jet and holder and make sure this hole is not plugged somehow. This being blocked would cause your problem. Unlikely...
Apr 6, 2024
Bird Brain
Dumb question but i have to ask, you have tried it with the fuel valve on instead of off like it appears in its current position in the...
Apr 5, 2024
Bird Brain
help identifying old cat (?) minibike
5/8"-18 thread (fine) by 7.500" length overall are your wheel bolts. Theres pics of some of the random stuff your bike originally most...
Apr 5, 2024
Bird Brain
Odd exhaust pipe
Is that clamp at the end spray painted or chrome like the rest of the pipe? Hard to tell from the picture. Clamp looks added to fit...
Mar 22, 2024
Bird Brain
liked
partyofone's post
in the thread
"Before and After" pics
Before and after ARCO Colt
Mar 15, 2024
Bird Brain
liked
Minimichael's post
in the thread
This was my go to..
This wrench got me through my childhood. Up until my kmart socket set.
Mar 3, 2024
Bird Brain
Any ideas on how to fix this ?
Any chance the i.d. of that pipes close to the o.d. of a golf ball? Put a few hose clamps around the damaged section drawed up tight to...
Mar 1, 2024
