Briggs & Stratton 5hp flathead engine for sale! (Needs to go ASAP)
Hey y'all. I have a B&S 5hp flathead engine for sale. It comes with a custom carb delete intake, custom exhaust manifold (muffler in pics not included), miscellaneous parts (aka pistons, valves, etc). It does burn oil excessively because the cylinder walls are mildly scored. I did try to fix it temporarily with high temp JB Weld but don't think it worked. Carb also needs cleaning. Left side bolt hole for the carb mount on the engine block is threaded larger than normal. There is another gas tank/carb set that comes with the motor but would not recommend using it because the carb is messed up and the tank is full of rust and dirt. The tank/carb set on the engine, however, is perfectly fine. The motor does have parts on it off of a newer B&S 5hp flathead C/I engine. I'm asking $120 or best offer. Cash payment only to my address.
