Well,, mine is on it's way finally ...
Ordered my front end & sprocket Thurs. & it didn't get shipped till today, because of MM doing warehouse inventory.
The ''SURVEY15'' 15% off code worked just fine !
It is still supposed to be good for the rest of this month, through 1/31/19
Talked to one of the head reps with them the other day, & he let out that they are in the process of some new offerings coming up yet this year.
He didn't give me details, other than new model electric bikes.
I asked him if any of them might be Lithium powered, all he could tell me was that he didn't have details yet.
Am going to get the wife an E -1000, 1000 watt., & remove the 3 lead acid ''boat anchor'' battery's that run in series, & install 2 - 10s 4P ''11 amp'' 36v lithium packs in parallel, w/ built in ''BMS'' circuit monitoring.
2 of those packs weigh about the same as 1 lead acid batt !
Should remove around 20lbs of high center of gravity weight, & run about 1 1/2 hrs., with noticeable performance gains.
Plan on eventually putting one of these front ends on it also.
Ian
