Kill Switch on Engine not working
So after about 2 years of not starting, my preadator 212 ran into another issue, the kill switch doesn’t work, not even the stock on on the engine. My question here is how do i fix this, i am not good with wiring nor do i know how to identify the issue. Any held would be great!
Sooooo, you can start it? Just can't kill it? Ground can be dirty/loose. remove and re attach ground. That is the wire that is bolted to engine directly above the switch on the engine.
