Gas tank
Fourtogo
I needed a gas tank for my vintage 80-81 Margay Expert Kart. They come with a molded plastic tank . I have brand new one , but can’t stand the way it looks . Its only item I am deviating from stock . I used 50/52 aluminum, that I bent on my cheapO harbor freight break . Had to modify it to make it work with out C-clamps . Made a cardboard template to get visual sizing . Ordered from Lowbrow Customs so fittings , 1/8” top hat weld bungs 4ea . Also ordered 4ea closed 5/16” top hat mounting bungs for tank mounting tank . E-bay-d a 2 1/2” aluminum non vented cap and bung . Tank is 6 1/4” wide . Bent/broke the alum sheet pre template , I can weld just about anything . But I bow down any aluminum welding artist . So with thee pieces I treked to my buddys house and let lay his jewelry on the tank . So I end up with one feed 1/8” out let a sight gauge on the rear portion of tank < Just two 90deg fittings and a clear piece of fuel line . On top fuel cap and a vent with roll over in line check valve . I haven’t machine polished it yet will get to that on final assembly later . Bottom picture is on my dirt race kart tank , so you can’t a visual on sight tube set up .
Fourtogo
I am dividing my time between the Margay , and I am building a Bearkat Twister . I am going to do a Stainless Stain tank on the BKT . I Have the pieces already the stock Briggs tanks are soldered together , not a fan solder but for my 1/24 drag slot cars .
desert rat
They gave me a video of my first shoulder surgery. I still can't watch it and when they did my second one ten years later I told them not to even video it. I have to have my hand done now and I have part of a bone in my neck "missing" now. That one is probably from the bike accident in the late 80's . Good luck on your rehab. All I can say is get moving and stay moving with out the pain killers so you know when it hurts so you don't over do it.
Fourtogo
This video isn’t me it’s a representative surgery video . I dint know incision would be this big 5”
