B Brian shields New Member Oct 9, 2021 #1 Oct 9, 2021 #1 Have an hs50. Replaced points condenser and coil still no spark . Any help would be greatly appreciated.
Skipp Oct 9, 2021 #3 Oct 9, 2021 #3 http://www.smallenginesuppliers.com...cumseh_L-Head_Engines_Service_Information.pdf
mustangfrank Well-Known Member Oct 9, 2021 #4 Oct 9, 2021 #4 Brian shields said: Have an hs50. Replaced points condenser and coil still no spark . Any help would be greatly appreciated. Click to expand... Spark plug? Make sure kill switch isn't grounding.
B Brian shields New Member Oct 10, 2021 #5 Oct 10, 2021 #5 mustangfrank said: Spark plug? Make sure kill switch isn't grounding. Click to expand...
B Brian shields New Member Oct 10, 2021 #6 Oct 10, 2021 #6 I took kill switch wire off all together. Still no spark.
B Brian shields New Member Oct 10, 2021 #7 Oct 10, 2021 #7 Skipp said: Ok if you replace those items you’ll need to time it…. Click to expand... I never messed with the stator.
B Brian shields New Member Oct 10, 2021 #9 Oct 10, 2021 #9 Skipp said: Curious how you got the coil off and on? Click to expand... Just pinched the plug wire and it slid right behind the statator.
f4radar Well-Known Member Oct 10, 2021 #10 Oct 10, 2021 #10 I took one apart the other day and someone had connected the ground wire from the coil to the points lug...no spark
B Brian shields New Member Oct 13, 2021 #11 Oct 13, 2021 #11 f4radar said: I took one apart the other day and someone had connected the ground wire from the coil to the points lug...no spark Click to expand... I bought bad new parts .
