Finally got around to messing with the new build. I want a bike with lights, but also electric start. That leaves out the traditional Hs40 aluminum flywheel and lighting coil since there are no starter gear teeth.
I was able to get a charging coil/lighting coil and flywheel, but is is iron and has the non-points ignition.
It does supposedly have both AC for lights, and DC to charge a battery, which i would need for the starter anyways.
I'm betting i need some sort of voltage regulator on the DC side but i have no idea which one lol.
I used the wiring harness from an old lawn tractor that i got rid of early in the year.
Got out the old test light and volt meter and was able to figure out the wiring, was pretty easy.
The starter does clear the frame, it's pretty close though.
