I added a Comet TAV2 to a Coleman CT200 EX and used the OldMiniBikes Warehouse Riser Plate. I mocked it up to check the sprocket alignment and they are off by 3/16”. (I used an adjustable bar for snowmobile clutches to check the alignment and I confirmed that it was straight.)
What is the preferred method for aligning the sprockets. I considered cutting the rear axle bushing on the brake side and lengthening the sprocket side but I don’t think the brake will attached properly to the frame with that much removed from the bushing. The other option I considered is drilling out the riv-nuts on the bottom of the riser plate to give some adjustment and using washers and nuts to attach the plate.
