I just found this minibike at the Car Swap - do you Guys know what year it is ? And any information I might need -
How much oil ? I should change oil and gas although it does run but brakes are not working .
Id grab a Tecumseh service manual and go through the motor….it will tell you the oil capacity changing intervals etc….more than likely the brakes will Need relined or replaced….never use old gas….common sense 101….
Those are great mini bikes and I believe were a re-brand of the Gilson. I remember as a kid sitting on them in Wards dreaming of riding them . There is a dipstick on the left which should allow you to add oil to the right level and in front and rear of the motor has an oil drain hole. Thanks for sharing.
I had an XE 525, came as a 2 speed but missing the 2 speed stuff when I bought it. Had a Tecumseh H50, 5HP engine,the large frame small engines, yours probably has the same. Nice find
What's the purpose of putting the right fork leg on the left side and (I assume) the left leg on the right? (Notice that the casted-in Monster Moto logo is upside down-ish rather than right side up-ish.)
