Drag Bike For Sale
Temecula Bob frame with wheels and tires as shown.
Scrub brake
large engine plate upgradeable to big block.
Minidragbike engine as follows:
Champion block
Honda OEM crankshaft
Minidragbike ported Honda head with 28/25 mm valves
1.3 billet steel rockers
310 isky cam
Comp Cams heavy duty dual springs
ARC rod
ARC flywheel
tillotson 304WX carburetor drilled to HL348F specs on alcohol.
AGK exhaust
Flat top Honda piston and wrist pin machined to spec.
Solid dowel pins
Engine machined square to crank and milled according to MDB specifications.
aluminum catch can
Stainless steel fuel tank
Steering damper
Fuel pump
Premier Titan clutch
RLV gold chain
Idler sprocket chain tensioner
Bike clocked over 65mph prior to alcohol and 1.3 upgrades.
Please PM with questions if you are interested. Will ship by truck or disassemble and box for UPS or Fedex.
$1450 plus shipping
Also, I will have the engine inspected prior to final sale at no additional charge. If you prefer gasoline, arrangements can be made to change the carburetor and adjust the timing for gas.
The Temecula Bob Drag frames is one of best frames around .
i have the stretched drag frame and they are really nice.
i beleive his name on here is billyjoebob5 on OldMiniBikes.
thats one bad ass ride you have there.
Korndog, how come your selling this one? I just saw you ridding it yesterday. (nice bike)Are you going to build another one or are you going to come over with the Flat Track guys???
125ccCrazy
Nice bike Korndog....is that the frame you had for sale a while back as a roller?......
I need to find something simular for my WF build...
