i have 2 6hp tecs,
the black one,runs great and needs nothing.
the red one,has electric start,and what looks to be lighted coil? wiring coming out of the shroud.
it also has a dead rod,broken,with the piston somewhere up top
the caps laying in the pan im assuming since the crank/flywheel spins freely.
the black one,looks to be an Alum block?
where the red one seems to be Cast iron?
and weighs a ton.
can any parts interchange between these two like the lighted part and the starter?
or should i get a new rod<the way im leaning>
and rebuild it?
this motor is going on a big framed bike build so it needs to be able to carry weight.
plus im hoping the charging system will run a headlight taillight combo.
can i get a Good rod for a motor like this?
what would you do?
and weighs a ton.
and rebuild it?
what would you do?
