I bought a bonanza chopper project off member Cdownie this weekend (he actually hooked me up with a trailer load of stuff :thumbsup, I had figured on probably just tossing this actual frame in the garbage due to all the mods but I figured I may as well see what happens if I start cuttin' on it as the frame really was not as bad as it looked in the photos.
Here it is in all its glory, Had some big plates welded on for a sidecar at one time, engine plate cut off and moved forward, original footpegs removed and big honking footbar welded to the front of the moved plate, right frame notched out for a briggs, brake mount tab relocated etc..
Spent the morning going thru cut off wheels and discs, got it this far and will use the other frame for measurements.
Maybe I can save it I dunno :shrug: Garbage day is friday, I have till then :laugh:
