1/2
  1. FloridaMiniBikes
    Wanted, Tecumseh White 1/2 Gallon side spout tank
    I need a Tec. white side spout 1/2 gallon tank for front mount. if ya got one, (or two) with or without brackets etc, let me know the condition, price. Thanks.
  2. Racer
    Briggs & Stratton 60100 2 1/2 HP Ignition
    Here's page from parts list showing ignition. http://www4.briggsandstratton.com/miscpdfs/RNT/Antique%20Manuals%20FAQ/Antique%20IPLs/MS4234a.pdf Page 3 Want to remove kill wire and use tab on top of sparkplug to stop engine. Wire comes under points cover from coil. Looks like one...
  3. B
    Victor 4 1/2" brake drum assembly.
    Looking for 2 clean Victor brake drum assemblies in good working order. Were used on Simplex and Rogue mini bikes I believe. What I was told. Appreciate any help or leads. Thanks, Greg
  4. Biffmini
    1" Trail grips 4 1/2" length
    $7.00 each plus shipping. Nice, soft & flexeble. I have plenty.
  5. 125ccCrazy
    Anyone have a source for a 1 piece 4 1/2" band brake?
    I'm looking for a 1 piece brake shoe 4.5" band brake...I've bought 3 now and each one has the two piece lining which fits like crap around the drum, everyone kinks at the split between the linings and does not touch the drum in that area.. all are made in taiwan too so the quality is far from...
  6. K
    72 or 60 tooth rear sprocket 5" internal drum 3 1/4 hole pattern
    I'm looking for a rear sprocket in 72 or 60 tooth with a 5" internal drum with 6x3 1/4" hole pattern straight across. All I can find is 4 1/2 drum and the wrong bolt pattern.
  7. myjunk
    2 1/2 hp Clinton engine wanted horizontal shaft
    Looking for a Clinton horizontal 2 1/2 hp engine. I need it for my little gen minibike. Thanks
  8. markus
    1/2" axle supplier, or make my own??
    I am lining up a budget and parts sources for a possible upcoming build, 1/2" axles would work the best in this application or worst case a stepped down to 1/2" on the ends (but I already have the 1/2 id bearings in stock). I would like the threaded end on both sides type axles though if...
  9. B
    WTB a header for a 3 1/2 H.P Tecumseh side popper engine
    WTB a header for a 3 1/2 H.P Tecumseh side popper engine in nice condition with bolts. Thanks.
  10. Biffmini
    3 1/2 Briggs help
    I just picked up a 3 1/2 Briggs Mod. Type Code 91202 0016 01 9503603 It needs help finally got carb to tank screws out not w/o damage. Needle is froze ( maybe some soaking? ) Any tips? A little rust in...
  11. spencertrax
    1/2 a mini bike?
    Just saw this on an air cooled motorcycle Facebook group. Pretty neat old piece.
  12. derekbmn
    Early 60's (60' ???) Lauson (Tecumseh) 3 1/2 HP
    As the Title says.....Early 60's (possibly a 60 ???) RUNNING Lauson 3 1/2 HP. 5/8" shaft. PERFECT for your Rupp Dart Cycle Project :laugh: $225 Firm Shipped. Paypal Preferred
  13. John in MN.
    Quiet down header
    I hope this is the correct forum. I have a header on my chopper. It is too loud to drive around at shows. I need to tone it down a bit. Got any ideas? It is 1 1/2 " in dia. and about 5 to 5 1/2" in length to work with. If I could find a muffler I would weld it inside. Or a removable baffle. John
  14. OND
    Kickstand 4 1/2 '' Bolt Up Type
    Looking for a 4'' to 4 1/2'' kickstand for a Sabre. Bolt up type preferred .
  15. J
    NOS round gas tanks
    I have two NOS round gas tanks. They are 7 1/2" x 3 1/2" and have a 3/8" outlet. $42.00 each plus shipping (Pay Pal gift payment only thank you)
  16. george3
    Rupp 6" Rear Wheel
    Rupp 6" Rear Wheel Wanted. or the sprocket 1/2
  17. John G.
    Seat for sale
    I have this seat i would like to sell. It came off one of my arco's but is not original to the bike. Im not sure what this seat is originally from. Not a show piece but a good rider seat. It is 19" long, 5 1/2" wide in the front and 7 1/2" wide in the back, about 3 1/2" high before it kicks up...
  18. that_van_guy
    Manco Delta 1 headset bolt woes
    So the Delta 1 chopper I picked up the other day has some serious slop in the headset/fork/steering tube. a 1/2" bolt fits snug in the fork plates, but has play in the tube. It almost seems like it should have a bushing or sleeve between the bolt and the tube, but there isn't one. Did these...
  19. bandit 40
    Large Gas Tank
    I have this tank for sale it very clean inside/out and has been checked for leaks and would be great for a custom build. Im not exactly sure of what it was on originally . It measures 9 1/2" across 4 1/2" wide 5 1/2" deep The tank bracket spacing on the top is 2 1/4" center to center...
  20. K
    Go power wheels
    Pair of pretty nice Go-Power wheels.5 inch,no denting or scuffing,the rear has a little pitting on the inside ridge.Rear has a sprocket.I have NOT tried to take these apart,so the allen head screws are not stripped or rounded out.The tires look to be nearly perfect,they are General Jumbo...
