Well I've build a another flat track bike out of the infamous super Powell . I've taken off the Powell frame rails and foot plates . And I've gone with single down tube and still have the kart style motor mount . The foot rest are a one piece design that clamps on just like the motor mount does...
Howdy folks,
I have a maroon 67/68 Rupp C250 with a Tecumseh H25 25142F engine that has (what I believe to be) a very weak spark.
It nearly started but just won't commit to it. I cleaned the carb out and it looks great inside now, it practically looked great when I took it apart to begin...
I got the cat apart and blasted . There were 8 extra holes in the engine plate,Along with wallowed out bolt slots and 7 cracks. I welded it up with my limited ability and 110 volt flux core "splatter box", 4" grinder and a driml. I lopped of the hi way pegs and will spend another afternoon...
Hi , thanks for the welcome in the intro forum. Here is my first mini project. I was told it was a cat 250. The foot peg does not look original , but I don't know much other than what I learned here in the last few days. The head has a stamp of 8 d , but the decals look old and say 2 hp. I would...
Alright, figured I'd start a build thread to keep track of the progress on my CAT 250. It's gonna be semi-original, same orange color and wheels, but different engine, tires, small parts etc.
PICS:
Got it cleaned up and rust reformer primed tonight:
I was looking at the sprockets at OldMiniBikes for the cat but it doesn't say dimensions. Anyone know if this will work on my cat 250?
#35 Chain - 68 Tooth Sprocket for Cat Mini Bikes with Disc Brakes
I'm almost sure the spacing on bolt pattern is 1 and 7/8"
Any help would be greatly...
no part out local pick up perferred,
250 pick up, 275+shipping
no cracks, bends, good frame, brake setup is on there, only need brake, and cable to connect
I have this 1979 Suzuki Enduro with a 250 2-stroke on it that I have been foolin' around with for a couple days. I got it for $100! Anyway, I dont know much about these things and I had a couple questions that some of you guys might be able to answer.
1) There are two cables coming from the...
im am selling just the frame, forks, swing arm, and shocks and the motor if you want it, for $250 serial #9H988, needs work to be original.... or run as is.
located in sun valley ca 91352 will ship with out motor for another $50 to $60 depending on weight.
great running and looking condition, all stock, ready for a 6.5 and all the aftermarket parts,from Baja Doodlebug,Dirtbug Performance and Repair parts. and the cool sprocket adapter from Vette66 00. can be a great all around racer, the races are coming...... be ready. or use for a great begginer...
