arc rod
    ZH8 flat piston
    Sold
  3. Carlos
    Lightened HSSK50 rod
    I thought some of you guys might be interested in this ... Standard connecting rod 92g with oil thrower, 88g without Lightened and "stress relieved" to 88g with oil thrower, 84g without
  4. J
    HS50, Isky cam, ARC rod, timing,engine
    Here's a question to those who have done it. HS50, isky cam, same as yours, arc rod, cleaned and polished ports, stock rebuilt carb with better air cleaner, header, and basically every other tid-bit I found you guys doing. QUESTION: advance the timing ? and to what degree? With or without...
  5. E
    TC2 Torque Converter OR Billet Rod, Flywheel, and Removed Governor?
    I finally got my clone engine to run smoothly. Starts up each time and runs like a champ. However, I noticed that with my current gearing 12t/72t it has amazing acceleration with plenty of torque, but the top end sucks. I think I'm maxing out at 20mph before the governor kicks in. Debating if...
