arm
  1. BWL
    Champion Gen. II rocker arm question
    Are the gen. II rockers 1.3 ratio? I put up a quick video on my YouTube channel asking since many of my subscribers are go-kart enthusiasts. https://youtu.be/Pq3d_bBWbl4
  2. R
    Taco 22DB Brake Arm
    Does someone have the dimensions of the Taco 22DB brake stay arm they can share(length, height, thickness, length of bent sections, size of slot)? Also, was the outer brake cable stop/adjuster originally mounted to the end of the arm as shown in the picture?
  3. Possom point
    5hp Briggs governor arm leaking oil?
    Hey everyone, I was working on my other 5hp Briggs tonight, I've had this motor for a while and last time I messed with it the governor pivot arm was leaking from the motor side. So I messed around with it again and got it fired back up. Why would it be leaking oil where the pivot arm is...
  4. C
    In search of swing arm for a bc1400
    Not too, too sure what frame i have exactly. I believe its a bonanza bc 1400 and ive been looking for a swing arm for some time. Let me know what you guys have, or if someone knows how to fabricate one. Thanks in advance
  5. Wild800
    Aggie 98 Swing arm mtg question
    Hello all, Looking for pics or information on how the swingarm mounts to frame. I have bearings that seemed to be welded to the cross pipe on the frame. Pics I see seem to show a through bolt and nut and washer ?? Also on the jack shaft how is the mtg. there ? Thanks!! Mike
  6. D
    Trail horse swing arm
    I'm in need of a trail horse swing arm. If anybody can help me out i would appreciate it very much.
  7. B
    212 cc prediter engine governer arm. throttle troubles and removal
    i took a brand new out of the box 212 cc prediter engine and put the honda clone electrodes and flywheel on it. i ran the cord safely behind a heat sheild that i ground down slighly to accomodate it. the nut on the crankshaft goes halfway on (litterally half of the nuts threads are used) i used...
  8. M
    Broken Rocker Arm??
    Running a non-hemi 212 automotive style holders / keepers, stock rockers/pushrods, 26lb springs, SS valves 25/24 and turning 8200RPM. Contemplating Chamion rockers but has anyone actually had or heard of stock rockers breaking? Or is it more precautionary advice? Thanks, Doug
  9. FOMOGO
    Jackshaft Swing arm relatinship
    I am trying to figure out what is the best way to run a swing arm and the jackshaft in one mount. Along the way the Bonanza mounts work/look that OldMiniBikes sells. Is there a rule of thumb for the 2 points being to far away from one another? Or do they need to be as close as possible? I fell like I...
  10. RuppChopperPaul
    FS: Fox Thunderbolt Frame, Fork & Swing Arm
    $100 and shipping. Exact year and model is unknown. Previous owner added foot pegs (something must have happened to the originals), and they were put on crooked so I took them off. They also welded some angle iron to the bottom of the frame (see 2nd picture), I was able to remove the pieces...
  11. H
    Coleman CT200U choke arm won't move at all
    Hello, The gray choke arm located just above the fuel shutoff won't slide to the right as normal. In fact, the bike won't crank at all. My son got the bike on Christmas and I plan on calling Coleman for support, but I also wanted to see if anyone could offer any thoughts. It's been ridden...
  12. Midyrman
    Bonanza BC Swing Arm
    Looking for a nice swing arm for a BC1200. Prefer one that does not require any repairs, straightening etc. Thanks. Tom
  13. Not so mini bike
    Aluminum swing arm
    Brand new never used aluminum swing arm. Would work great for 10"-12" wheels or smaller. Maybe even 14". $45 plus shipping
  14. 8
    Rupp Roadster Swing arm Help
    Hello members, I'm trying to save my swing arm, it was really bad!!! It had several scabed on pieces and gobs of something that almost looked like weld. Any ways does anyone have a good pic of one so I know what it is supose to look like? When these were made were the two stamped parts of the...
  15. 8
    WTB, 12" wheels and swing arm for a roadster2
    Looking for both 12" wheels preferably 24 spoke, and swing arm for my roadster 2.
  16. JohnnyTillotson
    H60 Gov arm too far away for link
    Trying to set up my big block throttle brackets and i notice this engines governor arm doesnt swing anywhere close to what it should in order to connect a throttle link. Below is the maximum in each direction. Is this just a case of removing the arm and reinstalling in a better position or is...
  17. V
    Engine on swing arm what is it
    This frame the engine bolts and moves up and down with the swing arm. What kind of frame is this.
  18. Roadster 2 Swing Arm
    Rupp Roadster 2 restoration. The swing arm bushing is pinned/staked, making it difficult to remove the outer bushings. By drilling out the pin stake notch the bushings can be easily removed.
  19. RideSF
    WTB bonanza brake cable retainer and swing arm
    Looking for bonanza swing arm and brake cable retainer that bolts onto the swing arm. Thanks!!
  20. RideSF
    Brake cable retainer for bonanza swing arm
    Does anybody know where to buy the retainer that goes on the swing arm of bonanzas? All the ones from OldMiniBikes warehouse are too big in diameter. Thanks
