bad?
  1. R
    How do I know when clutch is bad?
    I put the bike together today and threw a chain on it but the motor doesnt seem to be running as freely as it should is the clutch gone on the bike or?
  2. P
    Is this bad? (Lighting Coil)
    I took a look at my lighting coil recently and discovered that one of the fins (laminations?) is a bit jagged/bent: Here's a close-up: Will this cause any problems, and if so, is there a fix? Also, there's about four decades of crud built up on this thing... how do you clean a...
  3. H
    Tote Gote sprocket...good or bad?
    Getting ready to replace sprockets on my 403 Gote and while the small 11 and 13 tooth sprockets are definitely too far gone, I’m not so sure about the #40-48 tooth. Being no expert on worn sprockets….what do you guys think? Keep it or trash it? In any event, all new sprockets will have to be...
  4. dajsnipe
    generator... good deal or bad?
    I was in Sam's club yesterday and saw this. It was the only one they had so I looked it over real good. Everything is there and it has never been run.... what am I missing hear? I remember anything with a Honda being allot more expensive. I don't need a generator often but when I do I need it...
  5. myjunk
    Do I have a crankshaft seal going bad?
    I am having trouble getting my Moto Skeeter to smooth out, now granted it is from 1972, but I have had the carb apart several times and cleaned it quite well. However I am still ideling fast and the mixture screw has no effect on how it runs, I can close it ,or take it out and it makes no...
