coated
  1. Not so mini bike
    Lil Indian sabre
    Everything is there. Brake, fenders, handle bars,foot pegs, repop seat and clutch cover with bracket. Also have decal. Front wheel cleaned and assembled. Rear is not. Have sprocket and hard ware. Frame is powder coated. $600 local pickup
  2. CarPlayLB
    Old style H35 blower housing needed
    I am in need of an old style shroud/blower housing that has the 4 studs for mounting the recoil. I am kinda picky and need it to be in pristine condition. I have a powder coated, dented one I can trade and a brand new late model unit complete with round recoil, and of course, there is cash...
  3. capguncowboy
    Rupp XL500 Starter kit
    Before you get too excited, this does not include the engine clutch cover, gas tank or brake calipers. This DOES include the Wheels (without tires), front disk, rear disk/sprocket, frame, swing arm, upper forks, lower fork bushings, throttle (with a worn out/cracked grip), light switch and...
  4. S
    Ceramic coated exhaust
    just got my pipes back from the coater and got the engine assembled. Cost me $70 for both coated with ceramachrome 1200* thermal coating inside and out.
  5. flpmurphy
    Well me my boy did a little work on his ruttman. Thought it was chrome cause some of the paint was missing and it polished really good. After stripping the paint it wasn't chrome bummer but thats okay. Had it powder coated his choice of color. I found this guy local only charge 90 bucks which i...
  6. Peekster
    Here is another project that I had in the garage hanging in the loft for 3 yrs. Picked it up from Randy a few years back and had it powder coated and never put together.
  7. chipper
    2015 Open Class , The Flymingo DB
    This will be my wife's rider , only way I could build one , lol ! Its gonna have a hemi , some chrome , suspension and be powder coated in magenta !
  8. BobColeman
    Harrison wildcat powder coated orange crush
    Wildcat roller new tires all new powder coat new bars new clutch new rlv chain springer forks all new bearings new jackshaft with sprockets new throttle new alum riser block will post pics as needed asking 700.00 you need a motor and rear sprocket for complete runner no fenders
  9. Peyote_Pete
    diamond coated turd
    This was a real piece of shit, Im 275lbs and this thing takes me 55+ havent reached the top end yet. Gx200 clone mikuni 22mm head shaved 0.065, 18lb valve springs, flat top piston, billet flywheel and connecting rod. 11.5-1 compression, promod jackshaft #41 primary chain. First build ever. Got...
  10. J
    Powder Coated Long Block
    Thought I'd show off my long block assembly I just got done powder coating for my second Baja. I used a Matte Black powder and masked off all the matting areas before spraying. 15 minutes at 375 and this is the result... I'm really happy... :) I'm hopefully have everything back together...
