gasket
  1. B
    gasket set question
    does the arcdj-1305 gasket set fit the yellow dupor engine?
  2. chadillac
    gasket maker
    would this be good to use to seal intake and exhaust! should I also sue a paper type gasket between? any feed back would be great. this is for a methanol jr dragster engine. Ultra Black® RTV Gasket Maker | Princess Auto
  3. W
    CHEAP!! Briggs diaphragms and carb to tank gaskets!
    Here is an older style briggs carb to tank gasket plus diaphragm Briggs & Stratton Diaphragm and Carburetor Gasket Kit 3 - 5 HP 270026 & 272409 | eBay Here is an newer style briggs carb to tank gasket plus diaphragm Briggs & Stratton Diaphragm and Carburetor Gasket Kit 3 - 5 HP 272538 &...
  4. C
    head gasket thickness?
    hey guys, im wondering what would be my best choice for a head gasket because i just had the head milled .065 thou.it is a 14cc head with all stock geom valves,the cam i have installed is a 276 from agk($140)IM NOT SURE WITH A .010 LONGER ROD AND FLAT TOP PISTON which gasket i will need? any...
  5. Rclinetx
    Do I need to File this down for proper gasket seal?
    Long weekend! Got all the parts in and began the install on a 6.5 Lifan (One bad A$$ motor) Made some minor adjustments and got the mini up and going. 1. On the lifan , I found by running the open header I had to take the factory air box off and let it breathe then she ran like a...
  6. Cotmullion
    WANTED Briggs 5hp Exhaust gasket
    As the title says, just the gasket which goes between the port and the pipe, used is fine. I am also after a new 5hp diaphram. I am in the UK BTW.
  7. tin solider3
    Briggs 3 HP Gasket
    I need directions to a website for a 3 HP Briggs Tank Gasket Here's a couple of pictures of it
  8. Strigoi
    new style clone side cover gasket
    i've got a new style clone side cover gasket that i'm not going to use. it's one of those things i don't want to throw away but i'm not sure if it's worth shipping. all you have to pay is $4.75 for the flat rate envelope i'd ship it in. it may be cheaper to get one from OldMiniBikes.com...
  9. nash1970
    gasket PN needed
    I need the PN for a flatty 5hp exhaust gasket :helpsmilie:
  10. C
    side cover gasket on clone.
    Do any of you guy's use 2 gaskets on your side cover? It looks like a gap, i know it is on right, and tightened right..:shrug: Looks strange looking down at it.
  11. COWBOY
    complete gasket sets
    recommendations on where to get complete gasket and seal kits for 3=8hp briggs
  12. COWBOY
    Does anyone have recommendations on where to get complete gasket and seal kits for Tecumseh 3.5 through 10 hp.
  13. badtec
    Clone Gasket
    I read everything on the locked "side cover gasket" thread. I need the 1 that is considered the wrong one. Anyone know the Honda part#?
  14. H
    what is this carb rubber gasket for?
    this was in a tech carb kit i just bought. i cant for the life of me figure out where it is supposed to go. is it for the carb bowl drain thing? i had two rubber grommets. this one and the o-ring for the side needle. this one goes where?
  15. saychz316
    clone side cover gasket blowing
    Please see picture below. My Harbor Freight motor is eating this gasket alive. Right where cylinder head meets cylinder. You can see the gasket sticking up above the threaded bung in side cover. At first i thought it was me not tightening the side cover down, as i did that once before and...
  16. C
    Gasket Making?
    Any of you guys ever make your own gaskets? I have tried a few times in the past, but recently I had success. I made new intake gasket sets for my Briggs w/ tillys, and I was surprised at how they came out. $5 for a 12" by 18" roll of gasket paper (or use the side of a cereal box:laugh:)...
  17. mmisterbungl
    Sunnuva...what gasket do I need??
    So I ordered the wrong gasket kit. I thought since the picture on ebay showed 6 gaskets, that ONE of them would be the right one. They were all the same damn shape. Anyone know what gasket kit I might need? The first thing you are going to ask me is "what are the numbers on the side of your...
  18. manchester1
    Exhaust gasket for HF 6.5
    I could use 2 exhaust gaskets for my HF 6.5 clones. Anybody have a couple for sale. Thanks :biggrin:
  19. I
    Needing thin head gasket for 8hp
    Where can I find a copper head gasket for an 8 hp briggs?? Thanks Bob
  20. wildman500
    blown head gasket
    Hey guys, so I scored a real honda gx390 for 125.00 bucks today. At least I thought it was a score. The motor fired right up and ran good. It came off a power washer. When I got it home I noticed black soot or oil right under the muffler right where the head meets the block. So I started it...
