leg
  1. manchester1
    WTB tecumseh dog leg muffler
    Help please. I need a dog leg muffler for my H30. I think they are the same as HS40 and H35. I have 3 of them but the angel is wrong. I need it to exit the top part of the engine. You can see the muffler I have on the engine is going the wrong way. I have cash, paypal or can trade for one...
  2. T
    Hot leg
    I see a lot of people without a cover on the clutch and when I sat on the bike for the first time, all I get is a lot of hot air blowing on my leg. I'm assuming that's normal since it is rotating pretty fast? Sorry for the dumb question, first bike ever!
  3. 7
    Spring stuck in fork leg - K&S bike
    I was pulling apart the K&S I have and discovered the front end is sprung! I had no idea, everything was so painted up and stuck it just seemed solid. Anyway, one leg came out fine, but the other... well, the spring is stuck. Hard. It (the spring) has a weird bend where it's been compressed...
  4. S
    Looking for Bonanza Chopper Sissy Bar Lower Leg and Spring
    Only need left side but would buy both. Thanks
  5. adarter
    Leg tire bike modgepodge?
    I should proof read,LRG tire minibike.
  6. Jamie1972
    TrailHorse black and white foot leg covers.
    TrailHorse black or white foot peg covers. These are NEW/ HIGH QUALITY REPRODUCTION COVERS. Perfect for your restoration, survivor or daily rider bike. 42.50 shipped. 52.50 shipped.
  7. Peekster
    Looking for a 1970 Rupp fork leg.
    Looking for a fork leg for a 1970 rupp. Thanks
  8. JimmyC
    When it all started.
    1972. I think it was a lil indian. String throttle and no fly wheel shroud (starter was broken). And yes it did catch the back of my leg on the fly wheel while riding (about 10 stitches). What a great memory.
  9. CarPlayLB
    Briggs coil differences
    I have two coils here for the Briggs 5HP engines. Both are supposed to be armature coils, meaning no points needed. One has a metal leg to sense the magnet and the other does not. Can someone help me understand why? I was told that the coil without the metal leg is the hotter coil for the later...
  10. S
    Wards / Gilson swingarm question
    Recently picked up a Wards 525 frame to build a rider. There is much previous owner engineering to fix. Having never owned one before my question is, are the legs of the swing arm supposed to be parallel? The one leg is 90 degrees to the shaft, the leg with the brake lever angles away from the...
  11. T
    Bonanza Front Fork Boot & Rear Shock Questions
    Im just putting together a BC-1200 that I bought a few months ago after re-paint and general restoration. I'm noticing that the bottom part of the chrome upper for the right rear shock has been beat in pretty good, in order to clear the chain on a larger diameter sprocket. Did Bonanza build them...
  12. Not so mini bike
    Motor restoration
    Is there anybody on here that is a restorer for hire? Like I ship my motor to you you strip it down clean get it running then paint it and put decals on. Would something like that be super expensive. I have motors and parts just need the leg work done. Ya I know I'm not asking for a lot right...
