mikuni 22mm carburetor
  1. A
    Cam upgrade
    Hi, I currently have a ungoverned predator 212 non hemi with a high flow exhaust, mikuni 22mm carb with a bigger jet than stock (I forget how big I can look in the morning), billet flywheel, rod and piston, with a stock head. I am looking into buying a cam and was wondering which one would be...
  2. M
    Predator 212 on baja
    Okay guys, so I removed the governor on my predator 212 and put a new aftermarket carb and air intake and it won’t start tried cranking it 15 times. Any suggestions?
  3. G
    mikuni on 7 hp engine
    hi i wonder what to do with the guvenor arm? if i want to pit the mikuni 22 mm i saw some videos of how people put the arm to the front and tension the arm so its againt the internal guvenor inside? i dont want to remove the guvenor because i want the motor intact. i post som photos here for...
  4. Robertob
    Mikuni tuning issues
    Hey everyone, new to the forum and I could use some help. I have a 196cc with the following done to it: - Remove governor - New flywheel - Billet connecting Rod - Stock piston head - 1.3 ratio rockers - 22lb valve springs - mod2 camshaft - exhaust header - and breather on my mikuni vm-22...
  5. doug
    My first engine build.
    The parts arrived and I am really excited! The first thing I did was address the exhaust by installing a header and silencer. Now I’m working with the carburetor. After that a flywheel. Hopefully the fun will never end!
  6. F
    Wanted: Manifold for a 22mm Mikuni Carburetor
    I'm looking for a Manifold for a 22mm Mikuni carburetor. I'm located in California. Post pictures and Prices
