Currently in the process of building my Lil Indian small frame and I don't know what size bolt is supposed to go through the front end tube for the forks. I have a 5/8" bolt in there now but it is loose and wobbles. Bushing do not fit to solve this problem.
I have a Rupp Grand Prix. With the help of this forum it is believed to be a 1965. With 5" turbines on the corners which I believe to be correct. What size tires would be era approiate? I assume they would be square corner slicks but unsure of the actual tire size.
Any help is as always...
Hello OldMiniBikes forum! I need help finding the right size end bolt for the crankshaft of a 5hp flathead Briggs. So far I have tried:
5/16-16
5/16-18
5/16-24
None of them has even tried to thread in. Please help
Got a 5hp flat top briggs im tryn to bolt a clutch to but i cant seem to find the rite size bolt any one know what size bolt to blot the clutch to the crank
so i have a big manco dingo deuce go kart that i need a new sprocket for on the axle, right now it has a 54 tooth, so if i want it to have mor speed or more pull which direction do i go in number of teeth?
I'm going to be moving forward on a small frame lil indian bike and am looking for some suggestions for gearing. I plan to use the 6" wheels on it I can only squeeze the smaller 6" tires on and I think they are about 12" overall:shrug: I'm limited to a 60 tooth in the rear because of the disk...
This was on a snow blower that has a cracked gear drive on the blower the motor ran good but was of no use as a snow blower with the cracked gear case.What size engine is this and is it a winter duty only engine?
This is the info on the motor.
Model: 143.045001
Family:3TPXS.1951BF
DOM...
Go Kart & Mini Bike Tires
There are 2 methods used to measure tires:
1: If a "x" separates the 1st 2 sets of numbers the 1st number is the overall diameter of the tire. The 2nd number is the overall width. The last number represents the rim diameter.
2: Used for smaller and...
Just purchased an Azusa frame and fork setup from a local shop without wheels... Running a 6.5 motor if that matters. 6'2" tall around 180lbs.
:scooter:
What rim size should I go with? Going to order from OldMiniBikes warehouse. Thinking either the 6" Astro wheels with 410 X 350 X 6 tires or an 8" set...
I have a Baja warrior with a 41 tooth rear sprocket. I want to be able to ride, but pull the front tire up to lol. What size do y'all recommend? I've lightly modified. New Carb with bigger tube and jets. Header pipe, k&n type air filter and a 4° advanced timing key.
Pretty much have my mind set on building a Azusa kit up for some casual riding, nothing serious. At first I was set on the 8" kit, but now I am wondering if I should just save the money to start out and get the 5" kit instead. The engine I plan on using on the bike is the Harbor Freight Predator...
