[I]I have a army green version of the baja warrior that i am turning into a quick little street cruiser. It has a mildly built 212cc with a tav. I can tell that frame is bending under torque and the i weigh 215lbs so thats more stress. I want to know where are good places to put gussets and...
Ok so i have a drag mini bike...15hp with a tav2 12t. After install i know i need stiffer springs all around. I still have stock doodlebug rear sprocket (70t). To get more top speed would i go up in rear sprocket size or down?
I plan on running bike in the 1/8
and before i installed tav2 i...
I have a 212 with around 15hp and im going to run a 40 series torque converter setup but... They dont come with a mounting plate, they run by jackshaft. Would it be possible to mount 40 series on a tav2 plate or is there a reason the dont come with one?
Or..
Could i modify a tav2 to hold up...
Just installed a TAV-2 w/stock 2200rpm engagement, on a 205cc Briggs Gross Torque with 8.75 ft/lbs at 3600 RPM. I think its great, and climbs hills like nobody's business, but my friend who is about 100 lbs heavier doesn't like the mid range torque. Preferred the Max Torque for that.
I have...
