That flywheel is for the Hemi only. Do they make one for the non-Hemi?
I believe all that they had left when they went out of business was the hemi wheel. ARC has the new "Speedway" wheels with less fins...less drag...and with FREE shipping is nearly the same price as the "cheaper" wheel
https://www.OldMiniBikes.com/arc-speedway-billet-flywheel-predator-212cc-non-hemi.html
The new 6695 billet flywheel from ARC Racing for the Predator 212 NON-Hemi has an ultra low drag fin design that will greatly reduce air drag on your racing engine, while still moving enough air for cooling. Less air drag on the flywheel means more power freed up throughout the power curve, especially on the top end. This flywheel is designed for oval track racing.
This flywheel will have the same basic set up as the 6619. Recommended timing for unrestricted engines is still 34-36 degrees. Recommended timing for plate engines is 36-38 degrees. This flywheel also has a minimum coil gap of .030 as all our other flywheels do, meaning DO NOT set the gap closer than .030. However we use much more gap than that. Our testing shows on most unrestricted and plate engines that a coil gap of .065-.075 worked the best. The magnets in our flywheels are very strong and opening up the coil gap will help reduce magnet drag as the magnet moves underneath the coil. This is yet another advantage to our flywheels that will help free up more power in these engines.
This new 6695 flywheel has more power making potential than any other approved flywheel on the market. Our test as well as testing from other reputable companies shows it will make around the same power with zero tape on the blower housing as the 6619 does with the blower housing fully taped up.
Timing is 32 degrees BTDC with stock key. Flywheel weight 3.4lbs
and I like dealing with companies that are STILL in business!
