So I got a 14cc head, and was wondering if the valves from my predator will swap over I believe its the 3rd gen has split valve keepers, was also wondering what fuel I should run. Can I run regular? Octane Booster? Thanks
If your engine or head had the split keepers your valves will not fit, they are 5mm stems..the 14cc head will take 5.5mm valves....the most common valve stem size. If I were you I would get new SS valves and be done with it.
