What I got was a 196 clone block bored to 2.756." I talked to ACR today and decided I would do the 208. Going to run the 196 clone Clone crank and rod combo with the predator piston. I wanted to start with a complete motor on this build but looks like I am going to do it the hard way. The over bore block was only $5 more than a normal bore. ACR said with a +.020 crank it should put the piston just slightly below the deck depending on crank and block or around .003-.005 below. The predator piston is a lot more common than the UT2 I originally planned in the beginning. Want to put the piston as close to 0" deck as I can so if I want to play with compression a little later down the road. There are a few more options for the 196 as far as flywheels go too.
Throw a predator crank in there and you get 212cc. I wonder if they actually bore the block, or just send you a predator block? EDIT I dont see a predator block on their website, must be a 196 bored.
So this is what you ordered? Clone Block
