1966 Briggs Powered Schwinn Stingray
#21
Made a header with slash cut, and a chain guard for the primary. It's just hanging on the clutch in the photo. It's a challenge getting the ugly out of that primary side. I might streamline it a bit, and then paint and decal. No choice in the matter really. Ten pounds of crap in a five pound bag. Seat figured out. Since the drop out is over 2" wider than stock, the sissy bars have to widen, which caused torque on the seat mounting area. It'll be OK. Fab7.jpg Fab8.jpg
#25
I’m loving this build. I’m curious about the fuel tank. Is it ready made or custom built? I am studying this build closely. I usually plan my work years in advance and accumulate parts slowly
Thank you for your interest Augiedoggy. I fabricated the fuel tank. No one made anything like that. There are bicycle "gas tanks" but they're half pieces which house horns and the like and nowhere near adequate, not even with modification.
I bought a cheap English wheel and Shrinker Stretcher, and cut 18 ga mild sheet and formed it. Then I made the center portion and TIG welded it all together.
Augiedoggie
Very good. You did a fine job there. I don’t have the metal working skill set to attempt that sort of work but respect those with your ability. Well done sir.
Augiedoggie
Thanks. It was my first time doing anything like that. Watched videos, bought cheap tools, spent a week doing a job a master would have done in an hour.
I totally get it. I also study my project options carefully and spend far too many hours/days working until I’m somewhat satisfied with my result. My wife often refers to my workshop as “glacier garage” due to glacier speed of production here
#38
After I got done whacking off, (and grinding, highly recommend that power file) I opted to use some Hent.com Flexo plates mounted backwards. You can see in the subsequent photos the issue I had with them, and why I did not use them. However I will whack off some pieces of 10 ga and tack in beneath the plates as required, and it should do what I need it to. Fab10.jpg Fab11.jpg Fab12.jpg
#39
After looking at that space yesterday, I went back and read the whole thread, hoping to see why that space wasn't used.
We all knew you would never leave that shaft and sprocket down there. Great upgrade. and you can add a larger sprocket on the driven side if needed.
#40
I have not listed the minutae of every engineering decision here, and those of you who know me over the years know I do my own thing. The rationale for not doing the JS as I ended up was because of the lack of solid places to weld the plates, and the requirement for removing the entire jackshaft and the components, when removing the rear wheel/tire. I had to try the alternative. Anyway, this is what it is now, and I have remade the clutch cover mounts so I could rotate the cover and not have to drill new holes- which I wouldn't have, I would have had to make an entirely new clutch guard.
