Other than normal chain stretch and need of adjustment, it may need the sprocket centered better on the axle. With Lil Indians, there are three bearings to the rear wheel setup, two in the wheel and one on the sprocket. The best way to center the sprocket to the axle is to leave the wheel bolts a little loose, install the axle through all three bearings and then tighten the bolts gradually in a cross pattern prior to mounting the assembly on the bike.
