debris in the outside cam journal probably caused the bind, found that problem in an HS40 once, It moved the gear on the crank (they are pressed not pinned on that version engine) rather than taking the teeth off the camshaft. the governor system on the Medium frames also don't lubricate well since its up top so that's probably pretty toasted too. Bummer, the ball bearing sidecovers are a little tougher to find, I dont think they made bushings for the cam journals. The bearings on those cranks are real pain to remove, not so bad to reinstall if you heat the bearing in oil keep the crankshaft nice and cool though so the fridge and stove in your "shop" will come in handy, hopefully your landlord isn't on here!!!!!
