I have a 1971 arctic cat prowler mini bike with a sachs 50 motor in it. It will start and idle fine but if you give it some throttle it barley has enough power to turn the tire if it’s off the ground. We have tried a new carb and spark plug with the same results starting to wonder if it is possibly has bad crank seals any ideas what might be causing the lose of power would be appreciated thank you
