Here is a nice 1972 Speedway Red Baron, I cleaned up and detailed. I replaced the head gasket, points, condenser, ignition coil, new jackshaft bearing and belt, new rear brake cable and brake switch, new carburetor, grips, fork seals and dust caps. Original Carlisle tires and rare mirror, check out the huge original mud flap, on the front wheel. That will keep the dirt off of the motor. The muffler is not correct, missing the horn. The motor is a HS40-55389C, s/n 20173, frame # 35191. This motor has 2 oil caps, 1 is just a cap and the other is a dip stick ??. It is missing the clutch cover !! Anybody have one to sell ??
