Its a nice bronc, maybe you could find someone local that could weld on a bracket so you can use the caliper and sprocket as a disc. If you go with an o-ring chain, you can keep the sprocket dry and the caliper setup should work ok. The caliper setups are pretty inexpensive. Before I got 220v in the garage, the local muffler shop was very reasonable for these quick welding tasks.
