Today I attempted to rebuild the original diaphrarm carb on my 1970 Rupp scrambler.
I ran into a couple questions..
I removed the carb with the intake manifold still attached and noticed there was no gasket between the manifold and the block...is that right?
Second question, the diaphragm I am replacing had no gasket [or it was part of the diaphragm] the kit supplied a gasket as well as the diaphragm, where does it go? above or below the diaphragm?
Third issue, the new needle and seat was different that the one in the carb. I installed it anyway and found that the needle never seated. Fuel poured right thru it. I can reinstall the original so that isn't a giant issue but can one of you guys point me in the right directions on the gasket questions? Thanks, Jim
