Ya Ya,
Have a question,not sure if it can be answered though.Ok say you have a 3.5 modern Briggs engine in your frame.Now you pull it and put in a HF 6.5 engine in. Question is,will the chain still be in the same place? In other words will the chain be moved over more(towards mini frame tubing) since HF engine is larger? I did look at pics online and it appears like the 2 engines on the shaft side are either the same or very close to the same.The pull starter side looks wider on the 6.5.Hey Thanks...
