It certainly could, advancing/retarding timing changes the valve to piston clearance near TDC. Retarding cam causes less exhaust clearance and the exhaust is the critical V to P clearance. What compression and what style chamber are you running? Unless your running alky why are you running 38 degrees ignition advance? Is this on a minibike? Retarding the cam basically reduces low end and can increase high rpm power.
