So I just put a 390 carb on my predator hemi 212 and I think I may actually have it set right somehow.
I think…
It idles perfectly with the choke off and does not sputter or cut out when you get on it or at any point. And the spark plug looks like the mixture is just right. It’s actually a beast on the low end, I really have to feather the throttle and keep my weight forward when taking off to keep the front wheel on the ground. It’s a little scary.
The thing is. I’m still only getting the same top speed and rpm as I got with the jetted stock carb and cam, about 4200 rpm and 45mph.
Here are the details on the engine and bike:
I think…
- CT200UEX (170# rider)
- 212 hemi predator
- 30 series TC, 10&50 sprockets (knockoff brand)
- PVL flywheel timed to 32* (top speed was about the same at 28*)
- Arc rod stock length
- CM cam (top speed was about the same with stock cam)
- 22lb springs
- Homemade carb adapter, no (obstructions and I’m fairly certain it doesn’t leak)
- “390” carb ($15 Amazon one)
- Main jet drilled out to about 100 size (.040”) Maybe a little bigger. (It did ok with stock jet)
- Stock Coleman air filter bolted straight to the carb inlet (it did not like running without a filter at all, would not idle and always had to keep the choke mostly closed)
- Pilot screw turned out 5 or 6 turns (that much to get it to idle and stop sputtering)
- Homemade exhaust, 3/4” pipe about 14” long, set up to be able to have two of the cheap 3/4” mufflers or just wide open (top speed has been about the same in both configurations
- Anything I haven’t listed is stock/unmodified
