Those tanks did not ever drain from the bottom. They would collect years of gunk at the bottom if they weren't removed and dumped.
I have a couple of model 13 (5hp) tanks that had dunes on the bottom with a low spot around the pickup tube. The owner told me he had to remove the carb and tank several times to clean the little filter, but he never dumped the tank. They are still running irrigation pumps every spring and summer. I replaced the tanks.
How did you get the chunks out?
