This biggest problem is metal particles floating around.
I would not rev the engine and hold it at a high RPM more than a couple of seconds. Allowing the engine to go from idle to about 3/4 wide open many times in a row will help to seat the rings.
If it were my engine, I would drain the oil after 20 minutes of run time and replace with fresh oil. This should remove any crap floating around after it was washed free with the first run.
