I always looked at a 5hp intake port and figured fuel exits the carburetor and enters the stock intake port. Then has to slam the back of the intake port wall and I believe this could actually cause some fuel to fall out of the slip stream.
When the fuel falls out of the stream it pools in the bottom of the intake? And that pooled fuel would always just have to wait for the next intake stroke to even make it into the combustion chamber? (Those are questions I’m not sure if that’s true at all)
My thought process is add an epoxy ramp and close the port to a barrel. Give the fuel and air absolutely no where to go but the bottom of the intake valve waiting for it to open.
I have opened the port to the max before the epoxy. It‘s still a big port after the epoxy dried. I don’t see it being choked off. (Still mild cleanup work to be done)
