are you using the mount plate from cjtmini?
if not, just pull the old motor, drill/slot new holes and install the new one. after it's in figure out how to set up the throttle (it's been discussed here a lot and not that hard). just make sure the clutch sprocket and rear sprocket are lined up before you drill anything.
you might have to make a new chain too depending on where the motor is mounted.
