Picked up an old and completely stock Baja Blitz out a field on some property my parents bought and it was missing right grip/throttle/throttle cable, had a seized clutch and chain, and the caliper was beyond repair. I got it running as-is with a little elbow grease and PB Blaster but it wouldn't go under load(anyone on it) so I went shopping. Grabbed a grip/throttle kit, 6.5 Predator Hemi, PMR engine plate, hardware kit, throttle linkage kit, clutch, and chain.
Anyway it's all together and running but I noticed some things that I need more info on.
-Throttle is sluggish. I feel like I have to give it at least 1/3 throttle before the RPMs go up at all. It also seems like it takes a while to get going. I'm 6'2" @ 228lbs, so the latter issue may be due to me riding it.
-The throttle kit I got from HRMB took some tinkering and bending to get it installed correctly. Is this typical? It was nothing like the install instructions(which weren't that great, by the way). I added both L plates and the spring. I'll get a photo once I get the airbox assembly off again.
-The engine and plate moved a bit after my test drive causing the chain to loosen. Any tips to keep that from happening, such as lock washers or etc?
-I have the stock chain guard but did not get the big HRMB chain guard so the clutch is exposed. Apart from loose clothing being a risk, is there any other reason to get that guard or should I be fine without it?
-Are there any known issues or recommend modifications/alterations I need to know about with this motor, or is it cool to just run it as-is?
Thanks.
Thanks.
