Working on finishes for the gas tank. It's a hard thing to paint, so i tested my skills (or lack of them) on a Hustler tank. I gave up! instead i went with powder coating. Now powder coating a gas tank is tricky. Powder coat is burned in at 400 degrees F. Most solder melts at about 375 degrees. So i worked around this issue.
What i did was Tig weld the filler neck and the frame mount to the tank (these are soldered in place from the factory.) Don't need much, just enough of a weld to hold it in place (on the filler neck, just a small tack on two sides). Otherwise if the solder does melt, the tank pieces will fall off! so this keeps them in place during the process.
Next i bought some hi-temp 40/60 solder that melts at 460 degrees. It's only about 15% headroom, but if my powder coat guy's oven is accurate (and he insists it is), we should be safe. So i re-soldered the filler neck with the higher temp solder.
When powder coated, it was hung in the oven horizontally, so the solder (if it melts) has no where to go. It will just melt and stay in place, and them cool and solidify. After i got the tank, i did a quick pressure test and found the tank to be leak free.
Now i don't really recommend this process to people. I mean these are Rupp tanks, easy to get if things go badly. If you have some rare tank, where a replacement is impossible, you really don't want to do this.
Here's the result on the Hustler tank. I could never get this quality of a finish with paint! and certainly not get the durability of powder coat either. Will do the Black Widow tank next and see how that goes...
