'72 Arctic cat Ramrod. As seen condition.. wrong carb, no clutch cover. Missing one brake lever/cable. Missing air filter. Missing kickstand. Missing original throttle/grip. Kickstand mount has a weld. Exhaust pipe has been welded/jbweld?. Frame shows pitting from rust. I have headlight assembly not pictured.. the rubber headlight seal is dry cracked.. but could likely be glued and look nice. Wiring harness will need repair. Chrome has rust. New footpegs, relfectors and tail light lense.
Engine has good compression and runs on spray. Im sure it would run with this non correct carburetor if you hooked up a new cable/twist throttle. Tires have tread but show dry rot.
I will ship. Bike will have wheels and handlebars removed and packed with frame/forks/engine in a plywood box. It wont be cheap. I will use the carrier of your choice.. and you will pay actual shipping costs.
Prices is $500 obo
Located in owosso, MI, 48867.
Prices is $500 obo
