80CC Bicycle Engine Kit
Hi
If at first you don't succede Try,try again
We picked up one of these kits
It was $85.99 Does say engine may not work
Looks like it was a return
Well think happy thoughts!
Have a good evening
Bob
Hi ct
Thank you for the tip about the cylinder
We had a Ford 292 with two sleeves in it Each one was put in a different way Pretty interesting
Just figured out there is no way to test run this engine
It is either put most of the kit on or nothing
Have a good evening
Bob
cl350rr
Bob,
you can remove the magneto side cover (left side when mounted in the bike) and there is a nut on the end of the crank, you can turn that with a drill to test fire it.
BTW, this is what a failed aluminum cylinder from one of these looks like:
Good morning
This same seller carries 15 or 20 of these same type kits
What the difference is I do not know
Search his items for sale Then search 'bike engine kit' Then sort low to high price
Have a nice day
Bob
Now kit will get here tomorrow
They can be hit or miss I have 3 or 4. I had one I bought new never could get it to run quite right. I went through the whole thing tried new carb and ignition stuff. Eventually found a bike out for garbage that they obviously never got going I put that engine on and now its good. You can get a pull start for them aswell but they are usually so hard to start its best to bump start them
Hi Jeep
Thank you for the good advice
Opened the box
1 It looks like it has been run Exhaust pipe is discolored & has gasket left on it
2 Have not run across chain for it Maybe it under engine in it's own little box
3 Can't tell how clean engine is through baggie in poor light Will look at tomorrow outside in daylight
4 Sprocket is unused
Have a good evening
Bob
