Hi guys, I know some of you have alsport trikes, specifically the TS types with the wide 8” front tires. My question is how do or did you remove the front axle? They have what looks to be axles that are pressed in and through the bottom of the forks with a threaded hole in each end so that a bolt with the right sized washer would hold each side of the axle from sloding out to the right or left side of the fork bottom. I will post some pics ASAP but Rich D. Raced one this summer, so if his is the same maybe he or Gumpit the trike specialist could chime in. Possibly remove in a press? So far a torch, months of liquid wrench recipes and sound beatings have not helped. Thanks
