The headlight pattern has taken a bit longer than expected but it’s coming along nicely. I have a few changes to make so I can get the body line in the part. I have been using my Saw Stop table saw. I highly recommend these table saws for safety. When in the safe mode the saw will stop and drop the blade if your hand touches the blade. Check out the videos showing them using a hot dog as a “finger”. It is amazing. The only drawback is when you are cutting wet wood, foam, or anything that might conduct electrical current you have to put the saw in safety bypass mode so the saw does not trigger the safety system, so if your finger does get in the blade it’s gone....
