It’s coming along nicely. Today I installed the front forks, tire, handle bars, brakes and throttle cables. My friend Jesse came up with a nice way to protect the paint if the front forks are turned to far.
News Flash! My son just uncovered an amazing piece of history on this very Amphikitty bike. I will reveal the story and information when we post the completion video tomorrow. Stay tuned.
You are correct. The rubber tire is vulcanized to the rim at the tire manufacture. With a little patience and time you can install a valve stem from the outside. I takes a small flat tip screwdriver with a long handle and long needle nose pliers.
Here are some photos of the finishing touches to the headlight mount and decals. Thank you Mike and Jesse for the help and design for the headlight bracket. Keep an eye out at the end of the video. You’ll see this very Amphikitty with the factory Amphicat race team at the first national ATV rally in Mt Snow Vermont,1970.
This has been a vey enjoyable build. I want to thank everyone who helped out in the process. Everyone one this site have been supportive and kind. I hope by sharing this build, the process to add a lighting coil to a Briggs engine, bearing and seal part numbers used on this build will help people restoring an El Burro. I will post the video today.
I took the Amphikitty out for a ride through the trails. It's running and riding great! I would like to Thank everyone commenting on the build and Thank you for the likes.
like the route you went with the lighted coil setup keeping it under the stock recoil or I should say the stock points setup recoil. there is another way to setup lighted for a briggs ,but that involves using a newer deeper style recoil cover and would just not work with your project.
nice job................Real Nice.
I removed the engine to work on getting spark and to remove the fuel tank. I tried opening the fuel cap and the tank threads came with it.
also the did the first oil change on the old girl in years. View attachment 257667View attachment 257668View attachment 257669
