I do very little stainless on mini bike stuff. The attached picture shows my MIG with its mild steel bottle on the back and a big [dangerously unchained] stainless gas bottle sitting on the floor next to it. It is required that I do enough stainless stuff in the hobby shop that buying the bottle and the roll of wire seemed [at the time] worthwhile. Got tired of cleaning up spatter and weld color when using the arc welder on stainless. The picture of the roll of stainless wire is included to point out that it is only a small 10 lb. roll but was about $130. It would be MUCH cheaper to continue using the arc welder with stainless rod. The parts that I occasionally make [for food processing machinery] are fabricated from rather thin 18 ga. stainless steel. Again, there has never been a problem with being able to do a good job with a small stainless rod, it was clean-up that pushed me over the edge. My point is that it costs hundreds to buy the bottle and contents and roll of wire when exactly the same thing can, and was, done with the arc welder. Same with cast iron. Often on small stuff I use the TIG to weld it. But big stuff is best done with Ni-Rod. I do a lot of cast iron because I collect antique engines [made mostly cast iron]and also have friends that don't want to mess with it as it requires weld preparation and preheating. Can't recall if I've ever done any cast iron on a mini bike.
I truly believe that anyone that gets to the point that they wish to do more to a mini, or any other hobby item, than just bolt on things and wants to weld things together is best served, dollar for dollar, to first buy an arc welder and with the left over capitol purchase other required tools. Especially as an arc welder will do a whale of a lot more, for a fraction of the cost, of a MIG. In my view, a guy that gets to the point of wanting a welder is also the kind of guy that will most likely continue to dabble in metal working. Therefore he will, sooner or later, have to have an arc welder even if his pockets are bulging with cash and he can buy any MIG he wants that very day. That same well moneyed fella would be well served to also buy a little 220 V. arc welder [for short money] while he is at the welding supply shop.
