I have a Prowler with a 47CC Sachs AMAX 2 cycle engine. I am in the process of restoring but the last time it ran many years ago, it would lose power once it warmed up.
Anyone have any suggestions?
A small engine tech suggested that the muffler might be plugged but if so, it is only partially plugged since I remember feeling exhaust venting from the back. If the exhaust needs to be cleaned, he said they used to use a torch to burn it out but gave no details on how to do that. Can I do it with a propane or MAPP torch? I'm assuming I'd remove the insert from the back of the muffler, heat it up, and knock it with a wooden handle or block. Anyone ever cleaned one? If so, how?
This tech also thought maybe one of the crankcase seals was bad and not allowing the case to "pressurize". I didn't know the case should build any pressure. Is he crazy for suggesting that would cause a loss of power, whether it is warm or not? I never had any fluid leakage from this engine but some of the case gaskets were in pieces 30 years ago when I last had it apart and I had no replacements. This time around I will be ordering a complete gasket and seal kit. I can't see how that would affect power other than the head and reed valve gaskets. Mine are in good shape.
BTW - the reed valve looks to be in excellent condition but I don't know how to test it.
Any other ideas on why it might lose power after it warms up?
