B&S throttle for 3.5
I know there have been comments and threads ion this, but could someone post photo of throttle for the newer ( last of the old stuff, not the Chinese B&S) Briggs 3.5 engine with tank below carb and slide levers for choke and throttle. Any help really appreciated, photo really appreciated.
tap out the hole with a 6-32 tap then a bottoming tap use a short enuff screw so the screw bottoms out so it dont come loose......the only issue i have had is the arm needs to be far forward as not to hit the air cleaner i even put a o ring under the air cleaner to raise it.......put a small washer on the cable then add a spring and small cable clamp........always run a kill button on the handle bar nothing worse than a stuck throttle
